Jura Drainage valve (2)
  1. Jura Drainage valve (2), Jura Drainage valve (2): step 1, image 1 of 3 Jura Drainage valve (2), Jura Drainage valve (2): step 1, image 2 of 3 Jura Drainage valve (2), Jura Drainage valve (2): step 1, image 3 of 3
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): step 2, image 1 of 3 Jura Drainage valve (2): step 2, image 2 of 3 Jura Drainage valve (2): step 2, image 3 of 3
    • Images front and back
  3. Jura Drainage valve (2): step 3, image 1 of 3 Jura Drainage valve (2): step 3, image 2 of 3 Jura Drainage valve (2): step 3, image 3 of 3
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): step 4, image 1 of 3 Jura Drainage valve (2): step 4, image 2 of 3 Jura Drainage valve (2): step 4, image 3 of 3
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): step 5, image 1 of 3 Jura Drainage valve (2): step 5, image 2 of 3 Jura Drainage valve (2): step 5, image 3 of 3
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): step 6, image 1 of 3 Jura Drainage valve (2): step 6, image 2 of 3 Jura Drainage valve (2): step 6, image 3 of 3
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): step 7, image 1 of 1
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): step 8, image 1 of 3 Jura Drainage valve (2): step 8, image 2 of 3 Jura Drainage valve (2): step 8, image 3 of 3
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Follow the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Schwarzstein
2,813 Reputation
13 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 206
All Time: 7,931
