Jumper EZbook S5 Touchpad Replacement
  1. Jumper EZbook S5 Touchpad Replacement, Touchpad: step 1, image 1 of 2 Jumper EZbook S5 Touchpad Replacement, Touchpad: step 1, image 2 of 2
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZbook S5 Touchpad Replacement: step 2, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 2, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 2, image 3 of 3
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZbook S5 Touchpad Replacement: step 3, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 3, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 3, image 3 of 3
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZbook S5 Touchpad Replacement: step 4, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 4, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 4, image 3 of 3
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZbook S5 Touchpad Replacement: step 5, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 5, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 5, image 3 of 3
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZbook S5 Touchpad Replacement: step 6, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 6, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 6, image 3 of 3
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZbook S5 Touchpad Replacement: step 7, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 7, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 7, image 3 of 3
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZbook S5 Touchpad Replacement: step 8, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 8, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 8, image 3 of 3
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZbook S5 Touchpad Replacement: step 9, image 1 of 3 Jumper EZbook S5 Touchpad Replacement: step 9, image 2 of 3 Jumper EZbook S5 Touchpad Replacement: step 9, image 3 of 3
    • Lift the touchpad out of the case.
2 other people completed this guide.
Zed Chen
223 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 59
All Time: 1,337
