John Frieda JFHA5R Reset and Test Buttons Replacement
  1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: step 1, image 1 of 1
    • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
    • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
  2. John Frieda JFHA5R Reset and Test Buttons Replacement: step 2, image 1 of 1
    • Use the spudger along either side to open up the power plug.
    • As the power plug is opened, the caution sticker on top of the plug will rip.
  3. John Frieda JFHA5R Reset and Test Buttons Replacement: step 3, image 1 of 1
    • Slide slightly up to remove the back cover of the power plug.
  4. John Frieda JFHA5R Reset and Test Buttons Replacement: step 4, image 1 of 1
    • Remove the red reset button by pulling it to the right.
  5. John Frieda JFHA5R Reset and Test Buttons Replacement: step 5, image 1 of 1
    • Pull slightly left then up to remove the yellow test button.
Lindsey Farley
113 Reputation
1 Guide authored
IUPUI, Team S5-G1, Baechle Fall 2017 Member of IUPUI, Team S5-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 479
