Jabra Elite 85h Bluetooth Module Replacement
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: step 1, image 3 of 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: step 2, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 2, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 2, image 3 of 3
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: step 3, image 1 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 3, image 2 of 3 Jabra Elite 85h Bluetooth Module Replacement: step 3, image 3 of 3
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: step 4, image 1 of 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: step 5, image 1 of 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: step 6, image 1 of 2 Jabra Elite 85h Bluetooth Module Replacement: step 6, image 2 of 2
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: step 7, image 1 of 2 Jabra Elite 85h Bluetooth Module Replacement: step 7, image 2 of 2
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
Ryan Callaghan
693 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 92
All Time: 1,259
