JBL Everest Elite 300 Headband Cushion Replacement
  1. JBL Everest Elite 300 Headband Cushion Replacement, Headband Cushion: step 1, image 1 of 1
    • Extend the headphone.
  2. JBL Everest Elite 300 Headband Cushion Replacement: step 2, image 1 of 3 JBL Everest Elite 300 Headband Cushion Replacement: step 2, image 2 of 3 JBL Everest Elite 300 Headband Cushion Replacement: step 2, image 3 of 3
    • Bend the hinge slightly, then remove the two .5 mm screws with a Phillips #000 screwdriver.
    • This will be repeated on both sides.
  3. JBL Everest Elite 300 Headband Cushion Replacement: step 3, image 1 of 1
    • Slide down the "Elite 300" tab.
    • Repeat on both sides.
  4. JBL Everest Elite 300 Headband Cushion Replacement: step 4, image 1 of 2 JBL Everest Elite 300 Headband Cushion Replacement: step 4, image 2 of 2
    • Use a SIM tool to push pin fully through and out.
    • Repeat on the other side.
  5. JBL Everest Elite 300 Headband Cushion Replacement: step 5, image 1 of 2 JBL Everest Elite 300 Headband Cushion Replacement: step 5, image 2 of 2
    • Go along the edges with the pick, and pull up, taking off the band.
  6. JBL Everest Elite 300 Headband Cushion Replacement: step 6, image 1 of 3 JBL Everest Elite 300 Headband Cushion Replacement: step 6, image 2 of 3 JBL Everest Elite 300 Headband Cushion Replacement: step 6, image 3 of 3
    • After fully taking off the band, you are now ready to insert in the new band.
    • When placing in the new headband, line up the holes as shown in image 2.
    • The headband is difficult to replace, however after lining up the holes, the headband will snap into place. Push into the plastic and push away from you. A click will happen indicating it attatching.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 78
