How to Iron a Waterproof Jacket
  1. How to Iron a Waterproof Jacket, How to Iron a Waterproof Jacket: step 1, image 1 of 1
    • Unzip your clean jacket and slide one half over your ironing board.
    • You only want to iron through one layer of the jacket. Ironing through two layers can create wrinkles in one side.
    • Flatten your jacket with your hands.
  2. How to Iron a Waterproof Jacket: step 2, image 1 of 3 How to Iron a Waterproof Jacket: step 2, image 2 of 3 How to Iron a Waterproof Jacket: step 2, image 3 of 3
    • Set your iron to its lowest setting.
    • Ensure that the steam function of your iron is off.
    • Steam can melt your jacket. If you can't turn off the steam function on your iron, be sure to drain the water chamber of your iron.
  3. How to Iron a Waterproof Jacket: step 3, image 1 of 2 How to Iron a Waterproof Jacket: step 3, image 2 of 2
    • Lay a towel over the area of your jacket that you'll be ironing.
    • Smooth the towel out with your hands.
  4. How to Iron a Waterproof Jacket: step 4, image 1 of 2 How to Iron a Waterproof Jacket: step 4, image 2 of 2
    • Starting near the center, iron the jacket in one smooth stroke running parallel to the zipper.
    • Only iron in one direction. Each stroke should go in the same direction. Change directions only when you move to a new section of the jacket.
    • Do not press down with the iron. Allow the heat and weight of the iron to do the work.
    • Always keep the iron moving. Stopping in one place can result in burnt fabric.
  5. How to Iron a Waterproof Jacket: step 5, image 1 of 3 How to Iron a Waterproof Jacket: step 5, image 2 of 3 How to Iron a Waterproof Jacket: step 5, image 3 of 3
    • Remove the towel from your jacket.
    • Inspect your work.
    • If it looks as though the iron did nothing, you can increase the heat of your iron by one setting and try ironing again.
    • If your work looks good, position another section of the jacket flat on the ironing board, re-cover it with the towel and repeat the process until your whole jacket is wrinkle-free.
    • Don't forget to turn off the iron when you finish.
Finish Line
19 other people completed this guide.
iRobot
1 Reputation
636 Guides authored
13 Comments
Thank you, good advice for younger generation who have clue.
keirakeith26 - Reply
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - Reply
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - Reply
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - Reply
I hope the non-English comment is also in the same form as the first 3.
Eva - Reply
Past 24 Hours: 57
Past 7 Days: 469
Past 30 Days: 2,209
All Time: 164,440
