Ion Air Pro Record and Stop Switch Replacement
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: step 1, image 1 of 1
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: step 2, image 1 of 2 Ion Air Pro Record and Stop Switch Replacement: step 2, image 2 of 2
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: step 3, image 1 of 1
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: step 4, image 1 of 1
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: step 5, image 1 of 1
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
Christopher Brandl
673 Reputation
5 Guides authored
UW Stout, Team S6-G2, Ogden Fall 2018 Member of UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 378
