Inter-tel IP 8660 Handset Back Cover Replacement
  1. Inter-tel IP 8660 Handset Back Cover Replacement, Handset Back Cover: step 1, image 1 of 1
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Back Cover Replacement: step 2, image 1 of 2 Inter-tel IP 8660 Handset Back Cover Replacement: step 2, image 2 of 2
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Back Cover Replacement: step 3, image 1 of 2 Inter-tel IP 8660 Handset Back Cover Replacement: step 3, image 2 of 2
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 657
