Installing iPod shuffle 3rd Generation Front Case
Front case replacement.
Author:
Matt Newsom
- Time required: 15 minutes
- Difficulty: Difficult
Replace a scratched front case to make your iPod Shuffle like new.
Embed this guide
With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Rear Case
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Be careful when using a metal spudger, as you may scratch the outer case.
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
Pry the rear case away from the front case.
Edit Step 5
Logic Board
Edit Step 8
Headphone Jack & Shuffle Switch
Pry the headphone jack from the front case with an iPod opening tool.
Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
This guide has been completed 0 times.
