Installing iPod Touch 3rd Generation Rear Panel
Rear panel replacement.
  • Add Note x
  • x 4
This guide shows how to replace the rear panel on the 3rd Generation iPod Touch.
Sections
first image
Add Note Edit Step 1 — Front Panel  ¶
  • The glass front panel on the third generation Touch has a plastic frame glued both to its outer edge and also under the wide black strips at the top and bottom of the device.
  • The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
  • Also, be mindful of the very thin and delicate touch screen ribbon cable (connector location shown in green) attaching the front panel to the upper left corner of the Touch.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Gently insert an iPod opening tool between the glass front panel and its plastic surround near the volume adjust buttons.
  • Rotate the tool away from the Touch to pry up on the glass panel.
  • The key is to work slowly and gently to avoid breaking internal components.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Insert the iPod opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
  • Do not insert the tool and run it down the edge of the front panel, as it will damage the front panel itself and the rubber strip along the plastic surround. It is best to work at one point, pry up, then remove the tool and reinsert it at the next spot to be pryed up.
Next » « Previous
