Page 1 of 1
Installing iPod Touch 1st Generation Display
- Author: Walter Galan
- Difficulty: Difficult
Cracked or faulty display? Replace it.
- View:
- Paginated
- Full width
Edit Step 1
Case
Opening the case is a tough and potentially dangerous task. A good amount of force is required to wedge the iPod opening tool in between the case seams. The case may be damaged if this step is not done properly. Make sure not to hurt yourself while opening your iPod.
Insert the small iPod opening tool into the seam in between plastic display panel and the metal back panel. The angled edge should point towards the metal back panel.
Hold the tool in place once it is wedged inside and the two panels are separated.
Edit Step 2 ¶
There are seven interlocking retaining clips on each side of the iPod. The large iPod opening tool will be used to separate the front panel from the metal back of the iPod.
Insert the large iPod opening tool into the right side of the iPod, with the edge of the tool pointing towards the metal back.
Gently enlarge the existing crevice by wiggling the large iPod opening tool and moving it to the right.
Continue doing so until the right side of the iPod is loose.
Edit Step 5
Logic Board
The battery is glued to the iPod's display, but no screws hold it in place.
Flip the iPod 180 degrees so it matches the orientation in the picture.
Carefully insert the spudger in between the battery and the display. There are routing cables underneath, so make sure you slowly pry the battery loose.
Edit Step 10 ¶
Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board.
Gently lift the logic board (and attached components) upward.
The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
Slide the spudger under the small portion of the logic board. The board should come loose once the spudger has slid almost all the way to the other side.
This guide has been completed 26 times.
Page 1 of 1
