Installing iPod Shuffle 2nd Generation Battery Replacement
Replace the battery in your 2nd generation iPod Shuffle.
  • Add Note x
  • x 9
Use this guide to replace your Shuffle's battery. Replacing the battery requires a fine-tipped soldering iron and knowledge of surface-mount soldering.
first image
Add Note Edit Step 1 — Logic Board Assembly  ¶
  • Before beginning, be sure your Shuffle is turned off as shown.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
  • Remove the plastic cover and set it aside.
first image
Add Note Edit Step 3  ¶
  • Remove the two Phillips screws from the headphone jack side of the Shuffle.
Next » « Previous
