Installing iPod Nano 5th Generation Display
See what's going on with a new iPod Nano 5th Generation LCD.
  • Add Note x
  • x 4
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Glass Panel  ¶
  • Insert an iPod opening tool between the outer case and top bezel near the screen.
  • Lifting up on the iPod opening tool, gently pry the top panel off of the device.
  • The bezel is attached with adhesive, and may require some force to remove.
first image
Add Note Edit Step 2  ¶
  • Use an iPod opening tool to pry the hold switch button off of the hold switch plate.
first image
Add Note Edit Step 3  ¶
  • Remove the two 3.2mm screws.
  • These screws are angled toward the outer case and are also very small. Use a sharp screwdriver and be careful not to strip the screws.
Next » « Previous
