Installing iPod Nano 3rd Generation Display
  • Add Note x
  • x 35
Replace a cracked or faulty display.
Sections
Tools
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Please be aware that removing the rear panel from the back of the iPod will cause considerable damage to the rear panel. We highly recommend purchasing an additional rear panel to properly reassemble the iPod.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • The rear panel is secured to the front case by eight clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
  • To free the tabs, they must be pushed toward the center of the Nano. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
  • To aid in visualization, the two clips boxed in red are located closest to the headphone jack.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
  • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, above the dock connector. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
first image
Add Note Edit Step 4  ¶
  • Insert a small iPod opening tool into the seam on the headphone jack side of the Nano, with the edge of the tool pointing toward the rear panel.
  • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the the two tabs attached to the rear case, pushing the clips toward the center of the Nano until both have been freed.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
  • Repeat the same procedure listed in the previous step to free the three clips along the hold switch side of the Nano.
first image
Add Note Edit Step 6  ¶
  • Insert an iPod opening tool into the gap near the top left corner of the Nano and work to free the three clips along the top edge of the rear panel.
  • After ensuring all tabs are free, separate the two halves of the iPod.
  • The rear panel is now free from the iPod.
first image
Add Note Edit Step 7 — Logic Board  ¶
  • With the rear case removed, the back side of your Nano should now look like this.
first image
Add Note Edit Step 8  ¶
  • Remove the following six screws:
    • One 1.8 mm Phillips.
    • Three 1.9 mm Phillips.
    • One 2.4 mm Phillips.
    • One 2.6 mm Phillips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Using a spudger, flip up the brown click wheel ribbon cable retaining clip.
  • The clip is hinged at the end nearest the edge of the case.
first image
Add Note Edit Step 10  ¶
  • Use the tip of a spudger to slide the click wheel ribbon cable out of its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board.
  • Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
first image
Add Note Edit Step 12  ¶
  • Use a spudger to flip up the display ribbon cable retaining clip.
  • The retaining clip is hinged about the end nearest the battery.
first image
Add Note Edit Step 13  ¶
  • Slide the display ribbon cable out of its socket.
  • The logic board is now completely disconnected from the front case.
first image
Add Note Edit Step 14 — Display  ¶
  • A layer of adhesive around the perimeter of the display holds it securely to the front case. The following steps require prying up on the display with a spudger to free it from the adhesive.
  • The display is inherently delicate due to its thin glass construction. In the next few steps it is essential to work slowly and gently while prying the display from the front case.
  • Insert a spudger in the gap between the front case and the display near the top right corner. Slowly and gently pry the display up at several points along the top edge of the display, working your way toward the left corner.
first image
Add Note Edit Step 15  ¶
  • Continue prying up slowly and gently on the display, this time starting at the top right corner and working your way down the right side.
  • Repeat this procedure on the left side of the display, working down from the top left corner.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • When the adhesive has yielded enough to create a gap large enough to fit your fingers between the display and the front case, lift the display and gently peel off the remaining adhesive to remove it from the front case.
For more information, check out the iPod Nano 3rd Generation device page.
Did you successfully follow this guide?
This guide has been completed 35 times.
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Plastic Opening Tools
Related Products
iPod Nano Gen 3 Color Display
$29.95 · 8 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
