Page 1 of 1
Installing iPod Nano 2nd Generation Logic Board
- Author: iRobot
- Difficulty: Difficult
Your iPod's motherboard controls just about everything on the iPod and includes the headphone jack.
- View:
- Paginated
- Full width
Edit Step 3 ¶
When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
Edit Step 11 ¶
Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
Edit Step 17 ¶
Be careful not to scrape the metal rings surrounding the connectors off the logic board. If you accidentally scrape these off, you won't be able to reconnect the replacement battery.
Use a metal spudger to carefully straighten the battery wires. Be sure to only touch one contact at a time.
Edit Step 19 ¶
Use a metal spudger to carefully pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display. By working from the inside of the display, you won't be able to accidentally pry up the clear plastic shielding.
This guide has been completed 9 times.
Page 1 of 1
