Page 1 of 1
Installing iPod Nano 1st Generation Battery & Logic Board
- Author: iRobot
- Difficulty: Very difficult
The motherboard/bat
- View:
- Paginated
- Full width
Edit Step 2 ¶
The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
Edit Step 3 ¶
Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
Edit Step 5 ¶
The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
Edit Step 10 ¶
Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
Edit Step 12 ¶
Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
Slide the logic board out of its holding brackets on the rear of the display.
The logic board is still connected to the iPod by two ribbon cables.
Edit Step 13 ¶
Disconnecting the following two ribbon cables may be challenging. To prevent straining the cables or connectors, you can only separate the two halves of the iPod about 1/2 inch during the process.
Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
This guide has been completed 11 times.
Page 1 of 1
