Installing iPod Mini Click Wheel
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 12
The click wheel receives the feedback of your fingers and transmits it to the logic board.
first image
Add Note Edit Step 1 — Bottom Bezel  ¶
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
first image
Add Note Edit Step 2  ¶
  • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
  • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
first image
Add Note Edit Step 3  ¶
  • Lift the metal retaining bracket out of the iPod.
first image
Add Note Edit Step 4 — Click Wheel  ¶
  • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
first image
Add Note Edit Step 5  ¶
  • Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
first image
Add Note Edit Step 6  ¶
  • Continue to pull back on the black plastic tab, use your other hand to press down on the click wheel, and begin to slide it out of the iPod.
  • It's important to press down on the click wheel as you slide it out. Otherwise, the click wheel could be scratched by the iPod's metal casing. To prevent the click wheel from getting scratched during removal/installation, you can place some blue painter's masking tape over the click wheel. It can be easily removed with no residue after all is finished.
first image
Add Note Edit Step 7  ¶
  • Continue to slide the click wheel out until it is free from the iPod.
For more information, check out the iPod Mini device page.
Did you successfully follow this guide?
This guide has been completed 12 times.
Required Tools
Spudger
$2.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Related Products
iPod Mini Gen 1 Click Wheel
$29.95 · 8 in stock
