Page 1 of 1
Installing iPod Classic Click Wheel
- Author: iRobot
- Difficulty: Very difficult
The click wheel receives the feedback of your fingers and transmits it to the logic board.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 1
Hard Drive
Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble. Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of iPod opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
Before opening your iPod, ensure that the hold switch is in the locked position.
Edit
Step 2
Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic iPod opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
Insert a plastic iPod opening tool into the seam between the front and back of the iPod.
Edit
Step 4
At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the iPod opening tools.
Edit
Step 5
Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
Edit
Step 8
Near the center of the display, carefully insert a metal spudger into the gap created by the iPod opening tool.
It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
Using the metal spudger, disengage the single clip on the top of the iPod.
Edit
Step 12
Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the iPod opening tools.
Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
Edit
Step 17
There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
Grasp the front panel assembly with one hand and the rear panel with the other.
Take a deep breath!
Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
Edit
Step 20
Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the orange headphone jack ribbon out of its connector.
The rear panel is now free from the iPod.
Edit
Step 23
On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
This guide has been completed 7 times.
Page 1 of 1
