first image
thumb image 1
thumb image 2
Add Note Edit Step 10 — Hard Drive  ¶
  • Use a small iPod opening tool to release the black hinge holding the hard drive ribbon cable. The tab will rotate up 90 degrees towards the logic board, releasing the ribbon cable.
  • Use your forefinger to hold the ribbon cable in place; disconnect the drive from the ribbon cable.
  • Make sure the hard drive rubber side bumpers are attached to the drive being installed. Use the hard drive rubber side bumper installation guide to accomplish this task.
  • If necessary, the blue foam padding on the hard drive might also need to be transferred to the replacement drive.
Next » « Previous
For more information, check out the iPod 5th Generation (Video) device page.
Did you successfully follow this guide?
This guide has been completed 81 times.
