first image
Add Note Edit Step 13  ¶
  • The front panel should now be free from the rest of the iPod.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14 — Display  ¶
  • Rotate the iPod so the black plastic tab is more accessible to you.
  • Use a small iPod opening tool (or your fingernail) to flip up the black plastic tab holding the display ribbon in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
  • Use your finger to prevent the cable from lifting upwards. Wiggle the display loose from the frame, and then pull it gently outwards to release the display's ribbon cable. You may need to lift the cable away from the two white pegs that poke through it near the edge of the frame.
first image
Add Note Edit Step 15  ¶
  • The display should now be free from the rest of the iPod.
Next » « Previous
For more information, check out the iPod 5th Generation (Video) device page.
Did you successfully follow this guide?
This guide has been completed 170 times.
