Page 1 of 1
Installing iPod 3rd Generation Case
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
- Author: Walter Galan
- Difficulty: Moderate
This guide shows how to remove the iPod 3rd Generation case.
Tools
- View:
- Paginated
- Full width
Edit Step 2 ¶
Opening the case can be challenging. Do not get discouraged if it takes you a few tries before the iPod is opened.
Insert a large iPod opening tool into the seam between the plastic front and metal rear panel of the iPod, near the headphone jack. The tool's edge should point toward the metal rear panel to prevent any accidental scratching of the plastic front.
Run the tool along the top seam toward the upper left corner of the iPod.
Edit Step 4 ¶
There are five retaining tabs on each side of the iPod.
With the large iPod opening tool still inserted in the top seam, press a small iPod opening tool into the gap you just created.
Run the iPod opening tool down the side seam, releasing all five tabs.
It may be necessary to wiggle the tool while working your way down the seam to free all the tabs.
Edit Step 5 ¶
Run the iPod opening tool around the lower left corner of the iPod and along the bottom seam to free the two retaining tabs near the dock connector.
Run the tool around the lower right corner of the iPod and along the right side seam to free all five retaining tabs.
The case of the iPod should now easily come loose. Ensure all retaining tabs are free before proceeding.
This guide has been completed 0 times.
Page 1 of 1
