Page 1 of 1
Installing iPod 3rd Generation Battery
- Author: iRobot
- Difficulty: Moderate
Battery not lasting long? Swap it out.
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2 ¶
Opening the case can be challenging. Do not get discouraged if it takes you a few tries before the iPod is opened.
Insert a large iPod opening tool into the seam between the plastic front and metal rear panel of the iPod, near the headphone jack. The tool's edge should point toward the metal rear panel to prevent any accidental scratching of the plastic front.
Run the tool along the top seam toward the upper left corner of the iPod.
Edit Step 4 ¶
There are five retaining tabs on each side of the iPod.
With the large iPod opening tool still inserted in the top seam, press a small iPod opening tool into the gap you just created.
Run the iPod opening tool down the side seam, releasing all five tabs.
It may be necessary to wiggle the tool while working your way down the seam to free all the tabs.
Edit Step 5 ¶
Run the iPod opening tool around the lower left corner of the iPod and along the bottom seam to free the two retaining tabs near the dock connector.
Run the tool around the lower right corner of the iPod and along the right side seam to free all five retaining tabs.
The case of the iPod should now easily come loose. Ensure all retaining tabs are free before proceeding.
This guide has been completed 125 times.
Page 1 of 1
