Installing iPod 2nd Generation Logic Board
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
Your iPod's motherboard controls just about everything on the iPod.
Sections
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
first image
Add Note Edit Step 3  ¶
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
first image
Add Note Edit Step 4  ¶
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
first image
Add Note Edit Step 5  ¶
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
first image
Add Note Edit Step 6  ¶
  • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
first image
Add Note Edit Step 7 — Hard Drive  ¶
  • Peel up the metallic tape attached to the top of the battery.
first image
Add Note Edit Step 8  ¶
  • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
first image
Add Note Edit Step 9  ¶
  • Carefully disconnect the orange ribbon cable from the hard drive.
  • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
  • Lift the hard drive out of the iPod.
first image
Add Note Edit Step 10 — Hard Drive Cable  ¶
  • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
  • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
first image
Add Note Edit Step 11  ¶
  • Slide the hard drive cable out of its connector.
first image
Add Note Edit Step 12 — Display  ¶
  • Lift the blue hard drive mounting bracket out of the iPod.
first image
Add Note Edit Step 13  ¶
  • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
first image
Add Note Edit Step 14  ¶
  • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
  • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
first image
Add Note Edit Step 15  ¶
  • Remove the 8 T6 Torx screws from the logic board.
first image
Add Note Edit Step 16  ¶
  • Lift the logic board up enough to disconnect the orange touch wheel cable.
  • Lift the logic board out of the iPod.
first image
Add Note Edit Step 17  ¶
  • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
first image
Add Note Edit Step 18  ¶
  • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
first image
Add Note Edit Step 19  ¶
  • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
  • Lift the display off the logic board.
first image
Add Note Edit Step 20 — Logic Board  ¶
  • Logic board remains.
For more information, check out the iPod 2nd Generation device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ in stock
Plastic Opening Tools
$2.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Device Products
iPod Earbuds (New)
$14.95 · 10 in stock
