Installing iPod 2nd Generation Hard Drive Cable
Author:
iRobot Difficulty: Moderate
Connects the hard drive to the logic board.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Sections Tools Relevant parts
Edit Step 1
Rear Panel
Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Edit Step 7
Hard Drive
Carefully disconnect the orange ribbon cable from the hard drive.
If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
Lift the hard drive out of the iPod.
Edit Step 10
Hard Drive Cable
For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
For more information, check out the iPod 2nd Generation
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing iPod 2nd Generation Hard Drive Cable. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 0 times.
