Installing iPhone 4S Upper Antenna
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
Internal prerequisite when front facing camera is removed.
  • Add Note x
first image
Add Note Edit Step 1 — Upper Antenna  ¶
  • Remove the 2.4 mm Phillips screw next to the headphone jack.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
  • Use a pair of tweezers to remove the upper antenna from the iPhone.
  • Before reassembly, be sure to clean the metal-to-metal contact point on the upper antenna (not the mating halves of its connector) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
For more information, check out the iPhone 4S device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
