Image #1
Add Note Edit Step 9  ¶
  • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Image #1
Add Note Edit Step 10  ¶
  • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
  • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Image #1
Add Note Edit Step 12 — Rear Camera  ¶
  • If present, use a pair of tweezers or an opening tool to remove the outer plastic ring located on top of the rear camera's flash assembly.
Image #1
Add Note Edit Step 13  ¶
  • Remove the following four screws securing the cable cover to the logic board:
    • One 2.7 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.2 mm Phillips screw
Image #1 Image #2
Add Note Edit Step 14  ¶
  • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
  • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
  • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
  • Remove the rear camera from the iPhone.
  • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
Image #1 Image #2
Add Note Edit Step 16 — SIM Card  ¶
  • Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
  • This may require a significant amount of force.
  • Remove the SIM card and its holder.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Plastic Opening Tools
$2.95 · 50+ In stock
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
SIM Card Eject Tool
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 11 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
iPhone 4S Display Assembly
$94.95 · 12 In stock
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
iPhone 4S Replacement Battery
iPhone 4/4S Liberation Kit
$9.95 · 50+ In stock
