Page 1 of 1
Installing iPhone 4S Rear Panel
Replace a cracked rear panel on your iPhone 4S.
- Author: Walter Galan
- Time required: 10 minutes
- Difficulty: Easy
Remove the rear panel to access the internal components of your iPhone.
- View:
- Paginated
- Full width
Edit Step 1
Rear Panel
Before disassembling your iPhone, be sure it is powered off.
Remove the two 3.6 mm Pentalobe screws next to the dock connector.
During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
This guide has been completed 49 times.
Page 1 of 1
