Installing iPhone 4 Verizon Volume Buttons
Replace the external metal volume buttons on your Verizon iPhone 4.
  • Add Note x
Use this guide to replace the metal volume buttons.
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Before disassembling your iPhone, be sure it is powered off.
  • Remove the two 3.6 mm Pentalobe screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
  • The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
first image
Add Note Edit Step 3  ¶
  • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
  • Remove the rear panel from the iPhone.
first image
Add Note Edit Step 4 — Battery  ¶
  • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board.
first image
Add Note Edit Step 5  ¶
  • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
  • Remove the battery.
first image
Add Note Edit Step 7 — Volume Buttons  ¶
  • Remove the three 1.6 mm Phillips screws securing the volume button bracket to the outer case.
first image
Add Note Edit Step 8  ¶
  • Pull the volume bracket slightly away from the outer case.
  • Use a pair of tweezers to remove the volume buttons from the iPhone.
For more information, check out the iPhone 4 Verizon device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
