Installing iPhone 4 Verizon Speaker Enclosure
Replace the speaker enclosure near the bottom of the iPhone 4 Verizon.
  • Add Note x
Use this guide to replace a blown speaker enclosure closest to the bottom edge of the iPhone 4 Verizon.
Sections
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Before disassembling your iPhone, be sure it is powered off.
  • Remove the two 3.6 mm Pentalobe screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
  • The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
first image
Add Note Edit Step 3  ¶
  • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
  • Remove the rear panel from the iPhone.
first image
Add Note Edit Step 4 — Battery  ¶
  • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board.
first image
Add Note Edit Step 5  ¶
  • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
  • Remove the battery.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7 — Speaker Enclosure Assembly  ¶
  • Remove the two 1.8 mm Phillips screws securing the dock connector cable cover to the logic board.
  • Remove the metal dock connector cable cover.
first image
Add Note Edit Step 8  ¶
  • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
first image
Add Note Edit Step 9  ¶
  • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
  • Remove the pressure contact.
  • When reinstalling the pressure contact, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Use the edge of a plastic opening tool to pry the Wi-Fi antenna cable up from its socket on the logic board.
  • De-route the Wi-Fi antenna cable out from under the metal fingers attached to the logic board.
first image
Add Note Edit Step 12  ¶
  • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
first image
Add Note Edit Step 13  ¶
  • Remove the small black spacer that was under the Phillips screw near the vibrator.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
  • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
  • Remove the speaker enclosure assembly.
  • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
  • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
first image
Add Note Edit Step 15 — Cellular Antenna  ¶
  • Remove the two 1.6 mm Phillips screws securing the cellular antenna to the speaker enclosure.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 16  ¶
  • Starting near the cellular antenna cable, use the edge of a plastic opening tool to peel the antenna off the speaker enclosure.
  • Continue peeling the cellular antenna off the speaker enclosure, being careful not to rip the gold bracket attached to one of its edges.
  • Remove the cellular antenna.
first image
Add Note Edit Step 17  ¶
  • When installing a new cellular antenna, be sure to slide the gold bracket over the ear molded into the speaker enclosure before sticking the antenna down.
first image
Add Note Edit Step 18 — Speaker Enclosure  ¶
  • Speaker enclosure remains.
For more information, check out the iPhone 4 Verizon device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
