Page 1 of 1
Installing iPhone 4 Verizon Earpiece Speaker
This guide has more recent changes. Switch to the latest unverified version.
Replace a blown-out earpiece speaker in your iPhone 4 Verizon.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace a blown-out earpiece speaker.
Sections
- Rear Panel 3 steps
- Battery 3 steps
- Dock Connector Cable 5 steps
- Rear Camera 3 steps
- Logic Board 8 steps
- Earpiece Speaker 1 step
- View:
- Paginated
- Full width
Edit
Step 1
Rear Panel
Before disassembling your iPhone, be sure it is powered off.
Remove the two 3.6 mm Pentalobe screws next to the dock connector.
During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Edit
Step 14
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
Remove the rear camera from the iPhone.
Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
Edit
Step 15
Logic Board
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Power button cable
Front facing camera cable
Digitizer cable
Display data cable
To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
Edit
Step 21
Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
Remove the logic board.
Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
Edit
Step 23
Earpiece Speaker
Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
If you wish to reuse the earpiece speaker, try not to tear the foam adhesive that secures it to the iPhone's case.
Remove the earpiece speaker.
The speaker may be glued to a ribbon cable. Use a second opening tool to hold the cable down.
This guide has been completed 3 times.
Page 1 of 1
