Installing iPhone 4 Verizon Cellular Antenna
Replace your iPhone 4 Verizon's cellular antenna.
- Author: Andrew Bookholt
- Difficulty: Moderate
Use this guide to replace the cellular antenna normally adhered to the speaker enclosure.
Sections
- Rear Panel 3 steps
- Battery 3 steps
- Speaker Enclosure Assembly 8 steps
- Cellular Antenna 3 steps
- View:
- Single page
Edit
Step 1
Rear Panel
Before disassembling your iPhone, be sure it is powered off.
Remove the two 3.6 mm Pentalobe screws next to the dock connector.
During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Page 1 of 3
