Installing iPhone 4 Verizon 5-Point Pentalobe Screws
Replace the 5-point Pentalobe screws with Phillips screws on your iPhone 4 Verizon.
  • Add Note x
  • x 7
Apple has substituted the two bottom Phillips screws near the dock connector with 5-point "Pentalobular" screws.
This guide will illustrate how to replace the Pentalobe screws with good ol' regular Phillips screws.
Sections
Relevant parts
first image
Add Note Edit Step 1 — 5-Point Pentalobe Screws  ¶
  • Before we proceed, let's make sure you have the correct tools for the job.
  • iFixit's iPhone 4 Liberation Kit includes:
    • One 5-Point "Pentalobe" screwdriver
    • One #00 Phillips screwdriver
    • Two 3.6 mm "Liberation" Phillips screws
  • Are you ready to break the shackles of hardware oppression and liberate your iPhone 4? Let's rock!
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
  • The 5-Point Pentalobe screwdriver should only be used a limited number of times because it has the potential to strip the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Peel and remove the two 3.6 mm Phillips screws from the iPhone 4 Liberation Card.
  • Both the Phillips and Pentalobe screws are really small. How small? See for yourself (highlighted in the second picture).
first image
Add Note Edit Step 4  ¶
  • Insert the two 3.6 mm Phillips screws into the screw holes using the provided #00 Phillips screwdriver.
  • Huzzah! Your iPhone 4 should now be liberated from those pesky "Pentalobular" screws.
For more information, check out the iPhone 4 Verizon device page.
Did you successfully follow this guide?
This guide has been completed 7 times.
