first image
thumb image 1
thumb image 2
Add Note Edit Step 22 — Display Assembly  ¶
  • Remove the following two screws securing the vibrator to the inner frame:
    • One 6 mm Phillips
    • One 1.4 mm Phillips
  • Remove the vibrator from the iPhone.
first image
Add Note Edit Step 23  ¶
  • Remove the 1.5 mm Phillips screw securing the front panel near the headphone jack.
first image
Add Note Edit Step 24  ¶
  • Remove the three large-headed 1.5 mm Phillips screws along the volume button side of the iPhone.
  • Keep track of the washers under each of the screws.
  • Tip: It can be tricky, but it is also possible to just loosen the large-headed 1.5 mm Phillips screws slightly, without having to remove and replace the screw-and-washer set.
Next » « Previous
