Installing iPhone 4 Headphone Jack & Volume Control Cable
Replace a broken headphone jack on your iPhone 4. A new headphone jack will also give you new electronic portions of the silent switch and volume buttons.
  • Add Note x
  • x 47
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Rear Panel  ¶
  • Before disassembling your iPhone, be sure it is powered off.
  • Apple has recently substituted the two Phillips screws with 5-Point "Pentalobe" screws. If your iPhone 4 has 5-Point "Pentalobe" screws instead of Phillips, please refer to the second picture.
  • Remove the two 3.6 mm Pentalobe screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
  • The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
first image
Add Note Edit Step 3  ¶
  • Lift the rear panel away from the iPhone.
Next » « Previous
