Installing iPhone 4 Contact Clip
This is the clip that goes right next to the battery connector. It is sometimes called the pressure contact as well.
  • Author: Scott Head
  • Time required: 5 Minutes
  • Difficulty: Easy
  • Add Note x
  • x 27
Sections
Files
Tools
Tools (continued)
Relevant Parts
Image #1 Image #2
Add Note Edit Step 1 — Rear Panel  ¶
  • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
  • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
Image #1
Add Note Edit Step 3  ¶
  • Pinch the rear panel with your fingers and lift it away from the iPhone.
Image #1
Add Note Edit Step 4 — Contact Clip  ¶
  • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • Use an iPod opening tool to carefully pry the battery connector up from the ends closest to the top and bottom edges of the iPhone.
  • Do not pry against the contact clip.
  • Remove the contact clip from the iPhone.
  • Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the pressure contact as well as its contact point on the rear panel with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Phillips #000 Screwdriver
$9.95 · 50+ In stock
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Related Products
iPhone 4 Contact Clip (GSM/AT&T)
$5.95 · 38 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
