Page 1 of 1
Installing iPhone 3GS Volume Button
Replace the plastic volume button cover on your iPhone 3GS.
- Author: Andrew Bookholt
- Difficulty: Moderate
Use this guide to replace the plastic volume button cover, not the electronic volume switches themselves.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 2
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Be very careful when opening the iPhone so that the cables under the display are not severed.
There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
Edit
Step 4
Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1". (Cable 1 is for the display)
Be careful to insert the spudger from the left, as shown in the picture. If you try to pry up the ribbon from the right, you could damage the ribbon connector and need to replace the display!
All connectors except the ribbon connector mentioned in step 6 release upwards.
Edit
Step 6
Some iPhones may have the connector colors reversed (black plastic tab, white connector). Make sure you're flipping up the tab properly, otherwise you may damage the connector.
Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
Please note: You may find on some non-American (Chinese, European) versions of the 3G that the flip up plastic tab does not exist. In this case you would slide the ribbon cable towards the screen until it is removed. When you assemble it, you would apply pressure to the ribbon to insert it back into the ribbon "socket."
Edit
Step 12
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Note for re-assembly:
The screw that goes next to the camera (bottom right orange highlighted screw) also has a metal strip that holds the camera in place.
Remember to put this strip back in place before you insert the 2.3 mm Phillips #00 screws with full thread next to the camera
Edit
Step 14
Use a spudger to gently pry up the end of the logic board closest to the dock connector.
There is a small golden grounding tab on logic board adjacent to the 'do not remove sticker'. Ensure this does not snag on the side of the case when prying up the logic board.
If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
Edit
Step 15
Slide the logic board towards the dock connector and out of the iPhone.
When replacing the logic board after installing battery, connect the camera to the logic board before inserting it into the case. Then make sure to set the top section of the logic board (where the SIM tray is) in place before settling the rest of the board in place. This is important, as sometimes the SIM card slot will not align into place. Once the top section is in place, the bottom section can be maneuvered into place. You will know the logic board is correctly installed when the SIM tray is aligned with the opening in the iPhone case and the camera module seats neatly into its place.
Edit
Step 16
Use a spudger to pry the battery up from the rear panel. The battery is attached with an adhesive strip around the perimeter of the battery. To prevent the battery from bending during the removal process, we recommend against using just the plastic pull-tab . *Note: Removing the battery is NOT necessary for replacing the GPS antenna. It merely gives you more space for removing the headphone assembly (which is also unnecessary to completely remove).
The iPhone's battery is attached to the rear case with a mild adhesive. This adhesive usually comes out attached to the battery. If your replacement battery already includes an adhesive backing, you're all set. If your replacement battery doesn't have an adhesive backing, you'll want to transfer the adhesive from your old battery to the new one.
You can use a hair dryer or heat gun on its lowest setting to heat the back of the case. This will help loosen the adhesive bond before using the spudger to separate the battery from the case back.
Edit
Step 17
Headphone Jack
Remove the two Phillips #00 screws securing the on/off switch to the front bezel.
When replacing, check the protrusion of the switch. There is a small plastic spacer adhered to the inside of button which may come off with cleaning. Without a spacer, the button may not protrude enough to be depressed. If lost, it can be replaced with a suitable thickness of stiff plastic (eg shirt box lid).
Edit
Step 19
Remove the following 4 screws:
Three 1.8 mm Phillips #00 screws securing the headphone jack and GPS antenna to the rear panel. Note the order in which you remove the screws, as the left one has a slightly larger head.
One 3.8 mm Phillips #00 screw in the plastic loop near the headphone jack.
Edit
Step 20
Remove the four Phillips #00 screws securing the volume and mute switch.
The volume switch assembly sits on top of the mute switch. Make sure that the small soft pad on the mute switch is not lost, otherwise the mute switch will sit very loosely after reassembly.
The mute switch assembly screws should be tightened with the switch in the off position. Check the protrusion of the switch when turned on, since it may not stick out far enough to operate if the switch assembly is incorrectly positioned. (Check the gap between the switch frame and the bezel (white gap showing between the two screws near the 6). The screw on the far right is slightly longer than the other 3 screws. When reassembling the phone, keep this in mind.
Edit
Step 25
Remove the following 3 screws:
Two 1.5 mm Phillips #00 screws, one on either side of the dock connector.
One 2.4 mm Phillips #00 screw near the ribbon cable labeled "4."
Lift the dock connector assembly up and out of the iPhone.
When inserting the new assembly, ensure the screw holes of the assembly rest ABOVE the bezel's holes.
Edit
Step 26
In the following steps, you will partially remove the silver bezel attached to the rear panel. If the residual adhesive is not enough to hold it together during reassembly, it may be necessary to apply a light layer of glue around the inner edge of the bezel to keep it secured against the rear panel.
Insert the edge of an iPod opening tool into the gap between the silver bezel and the front panel on the volume button side of the phone.
Run the edge of the opening tool along the seam to separate the two components. The goal is to lift the silver bezel enough to push the volume button into the rear case.
This guide has been completed 27 times.
Page 1 of 1
