Page 1 of 1
Installing iPhone 1st Generation Rear Panel
- Author: iRobot
- Difficulty: Very difficult
The shiny rear half or your iPhone case.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 4 ¶
Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
Edit Step 5 ¶
Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
Repeat the same procedure on the other side of the dock connector.
Edit Step 13 ¶
Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
This guide has been completed 29 times.
Page 1 of 1
