View profile
Teams
Order History
Logout
« Previous
Page 3 of 3
Grasp the metal screw plate attached to the on/off switch and lift slightly up and away from the rear panel. The button should come with the cable.
Gently peel up the on/off switch ribbon cable. Be sure to pull near where the ribbon cable is glued to the rear panel.
The headphone jack is slightly recessed into the rear panel. First slide the headphone jack away from its housing and then lift it up slightly (only 1/4 inch or 1/2 centimeter) so that it is no longer in the rear panel.
Grasp the headphone jack at the tip and gently lift up, pulling the vibrator out of the rear panel.
Remove the two Phillips #00 screws securing the silent/ring switch to the rear panel.
Pry off the metal backing with the screw holes and save for securing the replacement switch.
Grasp the silent/ring switch and lift it up to reveal the screw beneath.
Remove the three Phillips #00 screws securing the volume switch to the rear panel.
Lift the headphone jack assembly out of the rear panel.
Next » « Previous
$2.95 · 50+ In stock
$4.95 · 50+ In stock
$29.95
$29.95 · 50+ In stock
$29.95 · 15 In stock
$39.95 · 37 In stock
$24.95 · 48 In stock
$24.95 · 16 In stock
1024
