Installing iPad Wi-Fi Speakers
Replace your iPad Wi-Fi's speaker assembly.
  • Add Note x
Replace the speaker assembly and restore sound to your iPad.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Display Assembly  ¶
  • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
  • Rotate the spudger away from you to release the tabs along the top edge of the display.
  • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • With one spudger, work your way along the right edge of the iPad.
  • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
  • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
first image
Add Note Edit Step 3  ¶
  • Lift the display assembly away from the rear panel assembly by its bottom edge.
  • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
first image
Add Note Edit Step 4  ¶
  • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
  • Be sure you are flipping up the retaining flap, not the socket itself.
  • Pull the digitizer ribbon cables straight out of their sockets.
first image
Add Note Edit Step 6  ¶
  • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
  • Pull the cable connector away from its socket.
  • Pull the connector parallel to the face of the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the display assembly from the rear panel assembly.
first image
Add Note Edit Step 9 — Dock Connector Cable  ¶
  • Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
first image
Add Note Edit Step 10  ¶
  • Remove the single 2.84 mm T5 Torx screw connecting the dock connector cable to the rear case assembly.
first image
Add Note Edit Step 11  ¶
  • Remove the two 2.84 mm T5 Torx screws securing the dock connector cable to the rear panel assembly.
first image
Add Note Edit Step 12  ¶
  • Carefully remove the plastic cover over the WiFi/Bluetooth board and dock connector cable using a plastic opening tool.
first image
Add Note Edit Step 13  ¶
  • Pry the Wi-Fi and Bluetooth antennas up off their respective sockets on the Wi-Fi/Bluetooth board.
  • Remove the dock connector cable from the rear panel assembly.
first image
Add Note Edit Step 14 — Speakers  ¶
  • Use the edge of a plastic opening tool to disconnect the speaker connector from the logic board.
  • Pry up from beneath the wires.
first image
Add Note Edit Step 15  ¶
  • Remove the two 2.84 mm T5 Torx screws securing the speaker assembly to the rear panel assembly.
  • If necessary, remove the tape covering the Wi-Fi cables.
first image
Add Note Edit Step 16  ¶
  • De-route the Wi-Fi antenna through its channel in the speaker assembly.
first image
Add Note Edit Step 17  ¶
  • Deroute the speaker cable connector through the left side of the rear panel assembly.
first image
Add Note Edit Step 18  ¶
  • Lift the speaker assembly and push it forward until the ports clear the bottom side of the rear panel assembly.
  • Remove the speaker assembly out of the rear panel assembly.
For more information, check out the iPad Wi-Fi device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
