Page 1 of 1
Installing iPad Wi-Fi LCD
Replace a broken LCD on your iPad Wi-Fi.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace your iPad's LCD.
Sections
- Display Assembly 8 steps
- Ambient Light Sensor 1 step
- LCD 8 steps
- View:
- Paginated
- Full width
Edit Step 1
Display Assembly
Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
Edit Step 2 ¶
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Edit Step 9
If you are reusing the LCD, it is not necessary to peel the ambient light sensor off the back face of the LCD.
Use the edge of a plastic opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
Once you've gained enough clearance, peel the ambient light sensor off the LCD.
Be careful not to crease the ambient light sensor below its top section, as the portion with adhesive applied may break off.
If necessary, attach the plastic view window to your new ambient light sensor before installation.
Edit Step 11 ¶
Remove the three T5 Torx screws securing the clips and LCD brackets covered in EMI tape near the home button switch.
Carefully peel the display clip and its attached tape off the black plastic display frame.
If you are replacing the LCD, be sure to transfer these pieces of EMI tape and their attached clips to the new LCD.
Edit Step 16 ¶
If it is still stuck to the front panel, remove the strip of EMI tape near the ambient light sensor socket.
If necessary, transfer this to your new LCD.
If it is attached to the LCD and you are reusing the LCD, skip this step. If you are replacing the LCD as well, transfer the strip of EMI tape to your new LCD.
This guide has been completed 19 times.
Page 1 of 1
