Installing iPad Wi-Fi Headphone Jack/Microphone Assembly
Replace a blown out microphone or a broken headphone jack on your iPad Wi-Fi.
Use this guide to replace your iPad's Headphone Jack/Microphone Assembly.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Display Assembly
Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Lift the display assembly away from the rear panel assembly by its bottom edge.
Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
Be sure you are flipping up the retaining flap, not the socket itself.
Pull the digitizer ribbon cables straight out of their sockets.
Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
Pull the cable connector away from its socket.
Pull the connector parallel to the face of the logic board.
Edit Step 9
Use the edge of an iPod opening tool or your fingernail to flip up the ZIF cable retaining flap on the headphone jack socket.
Be sure you pry up on the cable retaining flap, not the socket itself.
Remove the headphone jack from the rear case.
Make sure you transfer the rubber sound channel from your old microphone to the new microphone.
Before reinstalling the screws, be sure the headphone jack is properly seated in the headphone jack hole cut into the top edge of the rear case.
For more information, check out the iPad Wi-Fi
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing iPad Wi-Fi Headphone Jack/Microphone Assembly. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 4 times.
