Installing iPad 3G Front Panel Assembly
Use this guide to replace the glass front panel and digitizer on your iPad 3G.
  • Add Note x
  • x 14
Use this guide to replace a broken front glass panel.
Relevant parts
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Display Assembly  ¶
  • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
  • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
  • Rotate the spudger away from you to release the tabs along the top edge of the display.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
  • Pry the display assembly away from the rear panel.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
  • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
Next » « Previous
