Image #1 Image #2 Image #3
Add Note Edit Step 33 — Logic Board  ¶
  • Use a plastic opening tool to lift the display data cable lock upwards.
  • Pull the display data cable out of its socket.
  • Be careful not pull the connector upward as you disconnect it from its socket.
Image #1
Add Note Edit Step 34  ¶
  • Remove the LCD assembly from the rear panel assembly.
Add Note Edit Step 35  ¶
  • If present, use a plastic opening tool to help remove the piece of tape covering the end of the dock connector cable.
  • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
  • Peel the dock connector ribbon cable off the rear panel.
Image #1
Add Note Edit Step 36  ¶
  • Pry the speaker cable connector straight up from its socket on the logic board.
  • Be careful to pry only the connector, not the socket on the logic board, or you may destroy the socket.
Image #1 Image #2
Add Note Edit Step 37  ¶
  • Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket.
  • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
  • Peel the headphone jack and front camera cable off the rear case.
Image #1
Add Note Edit Step 38  ¶
  • Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
Image #1 Image #2
Add Note Edit Step 39  ¶
  • Use the edge of a plastic opening tool to flip up the retainer securing the control board cable connector to its socket on the logic board.
  • Pull the connector away from its socket on the logic board.
  • Do not lift the cable upward as you disconnect it.
Image #1 Image #2
Add Note Edit Step 40  ¶
  • Remove the two 2.1 mm Phillips screws securing the logic board bracket to the rear case near the digitizer cable socket.
  • Remove the logic board bracket from the rear case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95 · 21 In stock
Plastic Opening Tools
iFixit Opening Picks set of 6
$6.95 · 47 In stock
Related Products
iPad 2 Speaker Assembly
$89.95 · 3 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
