Installing iPad 2 CDMA Microphone
Replace the microphone in your iPad 2 CDMA.
  • Add Note x
Use this guide to replace a damaged microphone.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Front Panel  ¶
  • The iPad 2 is an extremely difficult device to open. Before attempting this guide, be aware that you may break your front panel and/or deform the plastic bezel around it during the opening sequence.
  • In the following steps you will use a heat gun to soften the adhesive securing the front panel to the rear panel. Try not to allow the stream of hot air to contact the thin plastic strip around the outer perimeter of the front panel as it may melt, permanently deform, and lose texture.
  • When heating up the front panel, the goal is to loosen the adhesive located in the areas highlighted in red in the second picture. When prying up the front panel, be especially careful not to damage the Wi-Fi antenna in the area boxed in blue, the top antennas in the area boxed in yellow, or the digitizer cable in the area boxed in black in the second picture.
  • Use a heat gun to gently heat the front panel to the right of the home button.
  • Do not heat up the home button, as it is plastic and easily melts/deforms.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Once the area of the front panel to the right of the home button has been heated adequately, it should be easy to insert a plastic opening tool between the outer plastic bezel and the front panel right next to the home button.
  • Use your plastic opening tool to gently create a small gap between the front panel and the outer bezel to the right of the home button.
  • If the adhesive is difficult to separate, don't be afraid to heat it up again. Excessively prying and bending the front panel when the adhesive is not pliable enough can easily cause it to crack.
  • Insert a guitar pick into the small gap created by the plastic opening tool.
first image
Add Note Edit Step 3  ¶
  • Heat up the area of the front bezel to the right of the home button along the bottom edge and make your way closer to the bottom right corner of the iPad.
  • Remember that this is where the wifi antenna is located and it is very easy to tear it.
  • Slide the first guitar pick toward the bottom right corner of the iPad and insert another guitar pick to maintain the gap between the front panel and the iPad next to the home button.
Next » « Previous
