Installing iMac Intel 27" EMC 2309 and 2374 RAM
iMac Intel 27" EMC 2309 and 2374 and 2390 RAM replacement.
  • Add Note x
  • x 31
Upgrade RAM modules for an instant boost in speed.
Sections
Tools
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
  • These screws will remain captive in the access door.
  • Remove the access door from your iMac.
  • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
first image
Add Note Edit Step 2 — RAM  ¶
  • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
  • Use your fingers to slide the RAM chip out of its socket.
  • If necessary, repeat this process for the other RAM module(s).
For more information, check out the iMac Intel 27" EMC 2309 and 2374 device page.
Did you successfully follow this guide?
This guide has been completed 31 times.
