Page 1 of 1
Installing iMac Intel 27" EMC 2309 and 2374 Bluetooth Board
iMac Intel 27" EMC 2309 and 2374 Bluetooth Board replacement.
- Author: Andrew Bookholt
- Difficulty: Moderate
Use this guide to replace a faulty Bluetooth Board.
Tools (continued)
- View:
- Paginated
- Full width
Edit Step 1
Glass Panel
Stick a suction cup near each of the two top corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel (as highlighted in the first and second picture).
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Edit Step 2 ¶
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
Edit Step 4 ¶
Carefully lay the iMac stand-side down on a flat surface.
Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
Edit Step 12 ¶
After removing the following screw, the Bluetooth board will be completely free of any connections and may fall.
Remove the single T8 Torx screw securing the Bluetooth board to the outer case.
During reassembly, do not over tighten this screw. It is threaded into plastic that is easily stripped.
This guide has been completed 1 time.
Page 1 of 1
