Installing iMac Intel 24" EMC 2111 Right Speaker
Replace a blown right speaker in your iMac Intel 24" EMC 2111.
  • Add Note x
Use this guide to replace a blown right speaker.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the two Phillips screws securing the access door to your iMac.
  • Both screws remain captive within the access door.
  • Remove the access door.
first image
Add Note Edit Step 2 — Front Bezel  ¶
  • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Lay your iMac stand-side down on a flat surface.
  • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
  • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
  • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
first image
Add Note Edit Step 5  ¶
  • If necessary, remove the strip of tape covering the microphone cable connector.
  • The microphone connector is located near the inside of top edge of your iMac.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Disconnect the microphone cable.
  • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
  • The camera cable connector and socket are delicate and easily bent. Remove with caution.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7 — Display Assembly  ¶
  • Peel the two highlighted EMI shield tabs off the frame of the LCD.
first image
Add Note Edit Step 8  ¶
  • Remove the two T6 Torx screws securing the display data cable to the logic board.
first image
Add Note Edit Step 9  ¶
  • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
  • De-route the inverter cable from its location next to the CPU fan.
first image
Add Note Edit Step 11  ¶
  • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
  • Remove the eight T8 Torx screws securing the display assembly to the rear case.
  • It is helpful to use a thin magnetized screwdriver to remove these screws.
first image
Add Note Edit Step 12  ¶
  • Remove the display assembly from the iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13 — Right Speaker  ¶
  • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
  • Peel the tape away from the lower corner of the right speaker.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • De-route the right speaker cable from between the logic board and the optical drive fan.
first image
Add Note Edit Step 15  ¶
  • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
first image
Add Note Edit Step 16  ¶
  • Pull the right speaker away from the logic board and remove it from the iMac.
For more information, check out the iMac Intel 24" EMC 2111 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
