Page 1 of 1
Installing iMac Intel 24" EMC 2111 Hard Drive Fan
Replace the hard drive fan on your iMac Intel 24" EMC 2111.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace a broken hard drive fan.
Sections
- Access Door 1 step
- Front Bezel 5 steps
- Display Assembly 6 steps
- Right Speaker 4 steps
- Logic Board 17 steps
- Hard Drive Fan 1 step
- View:
- Paginated
- Full width
Edit
Step 3
Lay your iMac stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Edit
Step 4
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
Edit
Step 23
Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
Edit
Step 33
Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel.
Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
When reinstalling the logic board, it is helpful to use tape to temporarily tuck the cables out of the way until the board is properly seated in the rear case.
This guide has been completed 1 time.
Page 1 of 1
