iMac Intel 21.5" EMC 2428 Optical Drive Replacement
  1. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Glass Panel: step 1, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Glass Panel: step 1, image 2 of 2
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Buy
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 2, image 2 of 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Display: step 3, image 1 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Display: step 3, image 2 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Display: step 3, image 3 of 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 4, image 1 of 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board. Twisting or pulling the display assembly with the cables attached will damage your iMac.
  5. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 5, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 5, image 2 of 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
  6. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 6, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 6, image 2 of 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 7, image 1 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 7, image 2 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 7, image 3 of 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards upwards.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  8. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 8, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 8, image 2 of 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
  9. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 9, image 1 of 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Optical Drive: step 10, image 1 of 1
    • From here, the repair will be easier if you flip the computer around so the base is facing you.
    • Remove the following four screws:
    • One 9.3 mm T10 Torx screw with a large head
    • Three 9.3 mm T10 Torx screws with a normal sized head
  11. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 11, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 11, image 2 of 2
    • Pull the optical drive thermal sensor connector straight up from its socket on the logic board. Pull parallel to the board.
  12. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 12, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 12, image 2 of 2
    • Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
    • Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
  13. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 13, image 1 of 1
    • Disconnect the optical drive cable by pulling its connector away from the optical drive.
    • Remove the optical drive from the iMac.
  14. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Optical Drive: step 14, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Optical Drive: step 14, image 2 of 2
    • It is not necessary to peel all of the EMI tape off the optical drive bracket. Only peel up the portion highlighted in red that is attached to the body of the optical drive.
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
  15. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 15, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 15, image 2 of 2
    • Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
  16. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 16, image 1 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 16, image 2 of 3 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 16, image 3 of 3
    • If necessary, use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
  17. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 17, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 17, image 2 of 2
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
41 other people completed this guide.
4 Comments
Great How-to, except the how to find the replacement Optical Drive... Can't find the 2428 online anywhere. Any help with the part number before cracking the iMac apart would be greatly appreciated!
swav1971 - Reply
Great tutorial. Now if I wish to replace the Superdrive by an SSD (the Superdrive is dead), since the SATA port of the Superdrive is 3Gb/s only, can I keep the Superdrive cable for the SSD but swap it plug to the free SATA III port on the motherboard? Or do I need a new cable?
Thanks
Emilio Imparato - Reply
What kind of caddy do I need if I want to put an SSD in there? Is it 9.5mm or 12.7mm? Is any of it non-standard?
Stefan Monnier - Reply
Hi! 12mm for imacs and 9 to macbooks... but 9 fits too cuz the place in imac is bigger (also 12 on macbooks not fit)
glecyo medeiros -
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 55
All Time: 37,081
