Installing iMac Intel 21.5" EMC 2389 PRAM Battery
Replace a dead PRAM battery in your iMac Intel 21.5" EMC 2389.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace the PRAM battery.
Sections
- Access Door 1 step
- RAM 4 steps
- Glass Panel 2 steps
- Display 7 steps
- Optical Drive 4 steps
- Optical Drive Fan 3 steps
- Logic Board 23 steps
- PRAM Battery 1 step
- View:
- Single page
Edit
Step 1
Access Door
Lay your iMac face-down on a soft, clean surface as shown.
Be sure there isn't any dirt or debris on your work surface, as it may scratch the glass panel on the front of your iMac. We recommend placing a towel between the iMac and the work surface.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
All three screws will remain captive in the access door.
Remove the access door.
Edit
Step 5
When installing new RAM modules, it is important to orient them correctly.
Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
Your iMac has four RAM slots. Be sure to slide each RAM module into its slot horizontally. This will prevent getting the modules stuck between two of the adjacent slots.
Once you have oriented the new RAM modules correctly, gently slide them completely into the iMac and use your thumbs to firmly seat them in their sockets.
Edit
Step 6
Glass Panel
Before beginning, unplug your iMac and lay it on a soft surface as shown.
Stick a suction cup near each of the two top corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Edit
Step 7
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
Page 1 of 6
